AutoCAD 2007/2008/2009
Member
Message 1 of 4 (371 Views)
AutoCad 14
371 Views, 3 Replies
04-18-2010 10:10 AM
Yes, I did something wrong and I don't recall what I did. Hopefully someone using AutoCad 14 can help me.
For weeks now, when I would check the diagonal distance of a line, the information at the bottom of the drawing would indicate the X axis dimension, the "Y" axis dimension and the "Z" axis dimension along with the angle of the "Z" axis line. Yet now, all I get when I check the distance of a diagonal line is the "X" axis dimension and the "Y" axis dimension. The "Z" axis dimension is not displayed and neither is the angle of the "Z" axis line.
Again, I haven't a clue as to what I did; so can anyone out there tell me how to correct this error?
*Pro
Message 2 of 4 (371 Views)
Re: AutoCad 14
04-18-2010 12:52 PM in reply to: akid1704
OSNAPZ? TREEDEPTH?
I hope my info was useful, but if by some odd chance it actually solved your issue, feel free to mark your post as "Accept as Solution". Thanks! :smileyhappy:
*Dean Saadallah
Message 3 of 4 (371 Views)
Re: AutoCad 14
04-19-2010 05:47 AM in reply to: akid1704
R14 discussion area is at:
http://discussion.autodesk.com/forums/forum.jspa?forumID=15
Dean Saadallah
http://LTisACAD.blogspot.com
Member
Message 4 of 4 (371 Views)
Re: AutoCad 14 Dimensioning Issues
04-20-2010 10:58 AM in reply to: akid1704
Yes, Modman_4;
I tried the two suggestions you provided and none of these worked. I also noted that this same issue occurs in every new and old drawing I create or pull up. As stated before, before I did whatever I did, I was able to click on the distance icon, move along my selected diagonal line, and read the "X"axis length, the "Y" axis length and the "Z" axis length, along with the angle of the specified diagonal line. Now all I can read when I check a diagonal line is the "X" axis length and the "Y" axis length. The "Z" axis length only appears as 0'-0".
Do you have anymore suggestions?
akid1704
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
