AutoCAD 2007/2008/2009
Message 1 of 6 (542 Views)
AutoCAD Version 2008 Properties
542 Views, 5 Replies
11-25-2012 08:01 AM
I am having a problem with properties. When I left clicked an object to find out properties - It picks-up the object however as soon as I clicked the right button the high light disappears. I have attached one drawing. I was trying to find out what size font on the text so that I could scale the drawings properly. Some settings have changed on my drawings and that is not allowing to do the Properties. Can somebody help me on this?
Alfred.NESWADBA
Message 2 of 6 (540 Views)
Re: AutoCAD Version 2008 Properties
11-25-2012 08:11 AM in reply to: apanbasu
goto _OPTIONS and verify the right-click settings
Also: if the objects get's deselected there would be some message in the commandline, isn't there any?
- alfred -
Alfred NESWADBA
Message 3 of 6 (354 Views)
12-22-2012 08:55 AM in reply to: apanbasu
I did not have any need for Autocad for a month. That is why I did not respond to your suggestion. II still have the same problem. I do not get any error message. I have re-installed AutoCAD 2008 thru control Panel. I have attached screen shop of my right click setting and a typical drawing that will not deselect when I click right button. I just noticed that if Typein "Properties" in command line the Property Window opens. The right click will not let me do that.
Alfred.NESWADBA
Message 4 of 6 (341 Views)
12-23-2012 11:01 AM in reply to: apanbasu
have you compared my screenshot and yours?
You have for the option "Edit Mode" ("If one or more objects are selected, right click means") ==> Repeat Last Command ... and not (like I have) Shortcut Menu
- alfred -
Alfred NESWADBA
Message 5 of 6 (336 Views)
12-23-2012 01:12 PM in reply to: apanbasu
I thought I have checked it. My Right-Click configuration short cut menu was not checked. Once I checked it - It is wooking. My question is how it got chaaged? Is it possible that when I receive drawings from other people that drawing causes the change?
Thanks for helping me out.
Alfred.NESWADBA
Message 6 of 6 (333 Views)
12-23-2012 01:17 PM in reply to: apanbasu
No, because this setting is stored locally on your machine (for your user-name), it's not depending on any drawing-files.
- alfred -
Alfred NESWADBA
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
