AutoCAD 2007/2008/2009
New Member
wgc_57
Message 1 of 3 (308 Views)
AutoCAD Frozen
308 Views, 2 Replies
11-18-2012 04:20 PM
When I open AutoCAD my mouse doesn't work.  Any suggestions oother than a re-install?
*Expert Elite*
Icemanau
Message 2 of 3 (294 Views)
Re: AutoCAD Frozen
11-18-2012 07:44 PM in reply to: wgc_57
Assuming it's a USB mouse, try unplugging it and then plugging it back in to re-initialise the driver.
If that doesn't work, Open ACAD, hit ALT-T then ALT-N. Now CTRL-TAB to the system tab and check your pointer settings. It should read "Current System Pointing Device" in the drop down box. If it doesn't, press TAB once and then the up/down arrow until it shows up. Now hit enter and you should be OK.
Regards Brad
Icemanau (NNTP handle: Brad Coleman)
*Expert Elite*
Alfred.NESWADBA
Message 3 of 3 (276 Views)
Re: AutoCAD Frozen
11-18-2012 10:54 PM in reply to: wgc_57
Does it not work in the graphics-area or also not in the menu-area?
If just not in the graphics-area of AutoCAD: have you activated SNAP? If so try to disable it using <F9>.
If the mouse does not work anywhere in AutoCAD how did you close it? Or did you have to use the task-manager therefor?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
