Hello
Welcome to the Autodesk/AutoCAD Forums !
I hope that we are speaking about Vista 32 bits !?
Maybe you could try to Install your 2007 with the Mode "Install as Admin"
and then try to run the same Way "Run as Admin" ... or maybe Select Win XP Pro compatible Mode !?
Patrice BRAUD
Hello
Please go back to the beginning !
Q1) Have you installed your ACAD 2007 32 bits on your Vista 32 bits without any problem ?
Q2) If YES, have you a problem when you launch your 2007 ?
Patrice BRAUD
Hello
Please look at this topic :
Maybe it can help you ...
or LONGBOW ...
http://www.longbowsoftware.com/
Patrice BRAUD
>> No I can't install it on Vista
If we ask now "why can't you install it?" what will you answer ... that's needed for us!
Just "it does not work" can't be answered efficient. What does the computer do when you start the setup, what messages does it show or why are you thinking "I can't install it"?
- alfred -
