AutoCAD 2007/2008/2009
Valued Contributor
Message 1 of 8 (3,120 Views)
AcDbLinetypeTableRecord Error
3120 Views, 7 Replies
08-19-2007 12:31 PM
When I try to edit a block in place I get the following error message.
Command:
Command: _refedit
Errors found in references to other objects:
** Application reference missing: ACAD, to AcDbLinetypeTableRecord.
*Cancel*
How do I fix this problem?
Active Member
Message 2 of 8 (3,120 Views)
Re: AcDbLinetypeTableRecord Error
09-07-2007 07:39 AM in reply to: Dhrd
I am having the same problem, even when bringing the linework into a new drawings file and re-blocking. Someone please help.
Here is the complete error message:
Command:
Command: _refedit
Active Contributor
Message 3 of 8 (3,120 Views)
02-22-2010 09:03 AM in reply to: Dhrd
anyone have any solutions to this?
I too am having problems with this - simply trying to edit a block in place
New Member
johnmarcus
Message 4 of 8 (2,802 Views)
08-11-2011 06:38 PM in reply to: Dhrd
i have this problem also... and still up to now autodesk cant give a straight answer to this...
*Expert Elite*
Message 5 of 8 (2,799 Views)
08-11-2011 07:08 PM in reply to: johnmarcus
Try moving the block to a vacant area of the dwg and then exploding it. Select everything to do with the block and explode again. Repeat until ACAD responds with a message saying XX Items not able to be exploded, with the XX matching the number of items selected for exploding.
Then just make the changes required and re-make the block.
Regards Brad
Icemanau (NNTP handle: Brad Coleman)
New Member
jobertandong
Message 6 of 8 (2,704 Views)
10-24-2011 07:23 PM in reply to: johnmarcus
i found out one common problem for this... its the leader... when you place a leader inside the reference in place... remove it and you can exit and save it...
hope this help
New Member
yannaingwinn
Message 7 of 8 (2,559 Views)
02-28-2012 02:17 AM in reply to: jobertandong
hope this help
That is correct.
I selected all leaders by using FILTER command and then changed to the another dimension style.
Then all just fine.
Thanks a lot.
Message 8 of 8 (1,919 Views)
03-01-2013 06:43 AM in reply to: Dhrd
Changing style did not work for me.  Even exploding leaders didn't do it.  I had to remove all leaders and MText from the block... that's when it worked again.
Jason B
Office CAD Guy
Oh... and Civil Engineer
Civil 3D 2009 and 2013
(wow that was a jump)
64-bit XP
i7 w/ 8GB Ram
ATI Radeon HD 2600 PRO
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
