• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    Valued Mentor
    shortcut and navswheel problem
    174 Views, 1 Replies
    08-31-2012 04:06 AM
    i d like to use SHIFT+W  as a shortcut keystroke for a command .
    i added this shortcut using the Cui , same as i did all the others .
    when i type my keystroke it does not launch the command ive chosen , it launches NAVSWHEEL  instead .
    NAVSWHEEL  is not listed in any of the cuis shortcuts . this seems to be an override .
    can this be fixed ?
    Please use plain text.
    Valued Mentor
    Re: shortcut and navswheel problem
    09-04-2012 03:46 AM in reply to: mrkaplan
