• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2007/2008/2009 DWG Format
    Valued Contributor
    milton.fitzgerald
    "AutoCAD Freezing Up."
    544 Views, 5 Replies
    02-20-2012 09:59 AM
    O.K.
    I just got a new install for one of my engineers, new computer, (HP Laptop) using Acad2008 (on our server license).
    Basically once he opens the program it freezes.... no mouse, or keyboard commands. The only way to get out of this is to use task manager. I see this has been a problem with the "Newer" versions of AutoCAD however, I've never seen this before with one of the older versions.
    Is there a fix for this ? I'm  currently surfing the net to see if this is an "OLD" problem, or a "NEW"  problem, that just occurs on new machines. BTW, prior to his computer upgrade the program was working fine.
    Also, we are opening "Plain-2D" drawings, no hatch, now LTS error problems.
    The only thing I can thing of, which I've seen on the replies is that the anti-virus software is interfering with the install, which wouldn't surprise me anymore.
    Any Help, or advice would be appreciated.
    Milton Fitzgerald
    (Milt a.k.a.-Drafter1981)
    Milt Fitzgerald (a.k.a. Drafter1981)
    Siemens Industries (Full-Time Office Position)
    Fitz’ Digital Cad Service L.L.C. (Consulting Business)
    https://sites.google.com/site/fitzdigitalcadservice/
    Please use plain text.
    Patchy
    Re: "AutoCAD Freezing Up."
    02-20-2012 11:51 AM in reply to: milton.fitzgerald
    2008 with win7? That would be a problem.
    Distinguished Mentor
    02-20-2012 04:57 PM in reply to: Patchy
    From looking at the attached JPG's your running Win XP on this system.
    Make sure that everything is fully up to date with all service packs and such installed on the O/S.
    Have you downloaded and installed the service packs for ACAD2008? If not, try doing that as it may clear the problem.
    Make sure to keep a copy of the service packs burnt onto a CD as well. Your IT dep will be able to help with that.
    Does the machin have a firewall installed? If so, is it configured to let ACAD access the network? This would be required for a network licence manager.
    Next step would be to either shut down or remove the A/V and try a repair of the install.
    Last step would be to remove ACAD altogether and do a clean install. Again make sure the A/V is disabled or removed.
    Regards Brad
    Icemanau (NNTP handle: Brad Coleman)
    You may recognize me from the
    hundreds of previous newsreader posts
    I've made over the last 5 years
    as Brad Coleman
    Patchy
    02-20-2012 06:10 PM in reply to: Icemanau
    :smileylol:
    How did i missed that
    dgorsman
    02-21-2012 11:40 AM in reply to: milton.fitzgerald
    After closing AutoCAD, check for a WsCommcntr process running in Task Manager as well as the acad.exe process.  This is associated with the Communication Center which is somewhat buggered in 2008.  If its still running, then it didn't terminate properly and prevents AutoCAD from properly terminating.  Kill all instances of both processes, then disable the Communication Center and try again.
    For the LTS (linetype scale, yes?) don't forget about annotation scales.  They are there and functioning even if you only have them set to 1:1, and should not be ignored.
    Adopt. Adapt. Overcome. Or be overcome.
    Valued Contributor
    milton.fitzgerald
    02-21-2012 02:48 PM in reply to: milton.fitzgerald
    O.K.
    I just wanted to let anyone that’s interested know we did solve this internally
     (at my full-time Siemens position).
    The fix was a combination of things similar to the post by “Icemanau” and “dgorsman” .
    Basically we wound up totally uninstalling AutoCAD, and had to clean out the registry, removing any instances that referred to AutoCAD, and do a new clean install.
    After that the program seem to work fine.
    I will not take full credit for this…
    Please refer to the outside links and quote I received from the person I was working with to help resolve the problem:
    “Quote”:
    This is what I used:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
    http://www.ehow.com/how_5941382_remove-autocad-software.html
    http://www.cadhelpcenter.com/2009/03/07/how-to-remove-all-autodesk-software-products-and-make-a-clea...
    The only thing I did different is I went thru safe mode to do this cleaning as I was afraid whatever was affecting ACAD was active so I wouldn’t be able to remove it from the registry
    With Regards,
    “Joshua G.”
    Good luck to anyone else that runs into this problem
    Milton Fitzgerald
