AutoCAD 2007/2008/2009 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
properties and quick select stop recognizin g dwg entities
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
What would cause the Properties command and the Quick Select command to stop recognizing drawing entities?
If I select some objects and hit properties it tells me no selection. Same in Qselect.
Ther is a variable that will shut off dialog boxes but I don't remembeer it.
Re: properties and quick select stop recognizin g dwg entities
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
"FILEDIA" should be set to 1 for dialogs, hope that helps
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
FILEDIA only controls the dialog box for finding & opening files.
There is another variable that turns off dialog boxes for other commands, INSERT for example.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I had exactly the same problem.
Go to Control Panel
Select Uninstall a Program
Select AutoCad 2008
It will offer a button to Uninstall/Change. Click it.
Select Repair or Reinstall
Select Repair my AutoCad 2008 installation and click next.
That's it. You don't even need the install disk.
Brilliant
