• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    New Member
    polyline looks "hollow" instead of solid
    2639 Views, 6 Replies
    02-26-2010 01:49 AM
    Tyring to pur a dashed line on a drawing. On some drawings it works fine, and looks like a dashed line of width 10 with a solid colour filling the full width of the line.
    However, on some drawings the very same procedure leaves me with a polyline that is not filled wioth colour, and I just have the outline of the line shown. When this happens, the line looks fine on layout space, but I would like it to look right in model space too.
    Any reason why the line behaves differently on different drawings, and any suggestions as to how I can get it to be a solid colour instead of just an outline?
    Wayne
    Please use plain text.
    *Dean Saadallah
    Re: polyline looks "hollow" instead of solid
    02-26-2010 05:22 AM in reply to: waynesurvey
    FILL variable
    SHADEMODE to set to 2D
    viewport has Hide turned on.
    Rotated UCS.
    Dean Saadallah
    http://LTisACAD.blogspot.com
    New Member
    cday7845
    11-30-2011 03:34 PM in reply to: waynesurvey
    I have the same problem.
    FILL is set to "1".
    SHADEMODE is set to "2D wireframe" (I am not using 3D for this drawing)
    Viewport is not hidden.
    However, I have changed the UCS.  How does one correct this problem with a rotated UCS?
    thanks!
    Cara
    JGerth
    12-07-2011 07:41 AM in reply to: cday7845
    do not use wide plines to represent line thickness, use lineweight property instead.  Or create the plines in plan view only.
    Valued Mentor
    LeafRiders
    07-04-2012 08:52 AM in reply to: JGerth
    I tried everything from multiple posts. SHADEMODE set to 2D was the 1 setting that changed it. Mind you FILLMODE is set to 1, and UCS - World, PLAN - World... were the other settings. Why do some people just change random things at random times, just leave normal alone or go paint on a canvas. :smileywink:
    New Member
    11-27-2012 11:31 AM in reply to: waynesurvey
    Spoiler
    I recently had the same issue but discovered it when I exploded a leader line. The arrow head lost it's fill but was still a solid. All the appropriate settings were correct. What solved the "Hollow" polyline and the arrow head issue was...from the VIEW pulldown----3d views----Top view. For whatever reason someone had changed the view of the drawing I was working on. Hope this helps.
    Ray
    Active Member
    12-05-2012 02:15 PM in reply to: ray.kuras
    I have had this happen a couple times to me and what I have found is that you are out of plane with the plan view. If you type plan to reset the view that has fixed it for me.
