• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    New Member
    opening acad drawings under 2009 problem
    74 Views, 1 Replies
    05-10-2011 05:23 PM
    hello - each time i try & open a acad drawing created under 2009 (2002, 2004, 2005, etc.) 2009 messages me that the drawing is corrupt & requires to run recover - i run recover & sometime the drawing will load other times another error message appears - anyone else have this problem & is there a setting or fix - any help would be appreciated - thank you
    Please use plain text.
    New Member
    CANOU
    Re: opening acad drawings under 2009 problem
    05-12-2011 11:03 AM in reply to: duk748
    It can be many things. Just verify if you have an "acad.err" somewhere in one of your folders,  delete it if it's  there.
    It can be a corrupted entity, make a WBLOCK of your drawing and try to open it again,
    Best regards,
