• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2007/2008/2009 DWG Format
    khacho
    new hatch palettes
    303 Views, 5 Replies
    05-16-2011 11:30 PM
    dear all,
    how to make new hatch palettes? pl. suggest me.
    thanks.
    khacho
    Please use plain text.
    Valued Contributor
    Re: new hatch palettes
    05-18-2011 06:13 AM in reply to: khacho
    I used a full hatch pallet in my 2008 ARCH ACAD.  I have spent two days trying to import the .xtp file and/or loading a new hatch pallet from scratch into ACA 2011, with no luck so far.  I too would like this tool  repaired, or explained.
    *Expert Elite*
    pendean
    05-18-2011 09:31 AM in reply to: FredBirch2025
    There are two kinds of palettes in ACA and they are not interchangeable: not a problem found in plain AutoCAD where you are posting. And I think the OP wants to create new ones in R2008 but forgot to elaborate on the exact issue.
    It seems your ACA forum posting got a lot of eyes (and a few comments from me) but not much else. Consider refreshing it by adding to it to bump it back up the list.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Valued Contributor
    05-18-2011 09:43 AM in reply to: pendean
    I probably should rewrite this on the ACA board.  I am having this problem on ACA 2011.
    The Arch 208 is the revision where I created and used the .xpt every day.  It is a great tool but I can't seem to transfer it or even reload the hatches one at a time.
    Please help
    How would I transfer this post to ACA
    *Expert Elite*
    pendean
    05-18-2011 03:04 PM in reply to: FredBirch2025
    I suspect... You probably ran ACA2008 "as AutoCAD". Regardless of what the box or the pop-up says, it's a feature of all the verticals.
    You are not running ACA2011 "as AutoCAD": to do that, see screenshot of OPTIONS command>Profiles Tab in ACA2011.
    There is nothing to fix therefore, you need to correctly install all of ACA2011's features and activate the correct profile.
    Valued Contributor
    05-18-2011 04:04 PM in reply to: pendean
    thank you
