• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    Active Member
    issues with loading tifs
    361 Views, 4 Replies
    02-15-2011 01:05 PM
    hi i am using LDD 2009 and everytime i go to load a tif image thru map- insert i get the error "Cannot open frame File .\AcMapCoordinateTransform.cpp Date: Feb 3 2009 Line: 221....the thing that makes it worse is if i click ignore a million times i can finally load the tif.. tried running a fix only seems to solve the problem for a lil while..if someone knows the way to fix this please help its driving me nuts!!!!
    Please use plain text.
    Valued Contributor
    CCDesigner
    Re: issues with loading tifs
    02-15-2011 01:16 PM in reply to: ryan5445
    Does this help?
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10851545&linkID=9240697
    R. Williams
    AutoCAD 2010 Certified Professional
    <!-- If all else fails hit F1 -->
    ---AutoCAD 2013---
    Active Member
    02-15-2011 01:27 PM in reply to: CCDesigner
    sorry forgot to mention i am running windows 7 and i was good until startup and recovery- settings then when it said to click the edit button i was outta luck since i do not have that button
    Valued Contributor
    CCDesigner
    02-15-2011 01:32 PM in reply to: ryan5445
    Oops, yeah, that would have been a good piece of information to know. I'm not running Windows 7 yet, but maybe someone who is can help you translate those instructions.
    Good Luck!!
    R. Williams
    ---AutoCAD 2013---
    Active Member
    03-17-2011 07:59 AM in reply to: CCDesigner
    can anyone please help with this problem i have unloaded the raster enablers and tried to reinstall i am using windows 7 and it seems no matter what suggestions i get they do not work, i've tried turning off the 3GB card that was suggested but still nothing
