• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2007/2008/2009 DWG Format
    Member
    Accepted Solution
    insert image
    302 Views, 4 Replies
    09-22-2012 02:22 AM
    Hello my friends
    I have a question about inserting images. Suppose we insert an image in AutoCAD , If we want to give this file to someone else, we have to put the image near the autocad file and give both of them !
    but, when we insert an image in word, powerpoint, exel and ... No need to share this image again !
    Is there any way that my images save in AutoCAD like Office ?
    :catvery-happy:
    Please use plain text.
    *Expert Elite*
    Re: insert image
    09-22-2012 07:00 AM in reply to: daria_davar
    you can, open the image in any software, mark an area, use function "copy". Change the focus to AutoCAD/to your drawing and then use "paste" to insert the image as OLE-object.
    But don't wonder then that the size of the DWG-file raises up (and may be the quality of printing is not as good as a referenced version of the image).
    To use _ETRANSMIT (a command that packs the DWG and the referenced files to a ZIP) would be the preferred method for transferring data to anyone else.
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    *Pro
    scot-65
    Re: insert image
    09-24-2012 02:56 PM in reply to: daria_davar
    Another method I have seen (but to this day have not figured out how he did it)
    is to insert an image into a DWG file, then insert that DWG file into the current
    DWG file as an unexploded block. I never did investigate if it was OLE... or not.
    Valued Mentor
    TerryDotson
    Re: insert image
    09-24-2012 05:27 PM in reply to: scot-65
    Something like this attachment, created with the Image Bind tool in ToolPac.
    Member
    Re: insert image
    10-07-2012 10:42 PM in reply to: alfred.neswadba
    thank you very much for your reply and solution
    :catvery-happy:
