• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    *GhysBoy
    hyperlink on a polilyne
    240 Views, 4 Replies
    01-24-2007 12:50 PM
    Hi all,
    I have a drawing and database. In my database i have 2 row. first is a code
    and the second is a hyperlink. In my drawing i have the same code in table
    of object data associate to a polyline. A link run properly between the
    database and drawing. It is possible to take the hyperlink in the database
    and recreate to to polyline associate too.
    Thanks for the way you give to my
    Ghyslain Baril
    Please use plain text.
    *Laurie Comerford
    Re: hyperlink on a polilyne
    01-25-2007 01:36 AM in reply to: *GhysBoy
    Yes, but if you have several, or more, to do, then you would be advised to
    create a program to do it.
    Laurie Comerford
    CADApps
    www.cadapps.com.au
    www.civil3Dtools.com
    "GhysBoy" wrote in message
    news:5462714@discussion.autodesk.com...
    Hi all,
    Ghyslain Baril
    *GhysBoy
    01-25-2007 05:07 AM in reply to: *GhysBoy
    Did you a a exemple for do that... what kind of code.... it's a lisp, or vba
    "Laurie Comerford" a écrit dans le message
    de news:5463143@discussion.autodesk.com...
    Laurie Comerford
    CADApps
    www.cadapps.com.au
    Hi all,
    Ghyslain Baril
    *Laurie Comerford
    01-25-2007 01:55 PM in reply to: *GhysBoy
    I did it in VBA.
    The code I used started from the Help files for VBA as shown below.
    The URLDescription displays when you hover the mouse over the object
    containing the hyperlink.
    One thing I was unable to do was add a line break into the display. If you
    discover that, I'd appreciate it.
    Laurie Comerford
    CADApps
    www.cadapps.com.au
    Sub Example_HyperLinks()
    ' This example creates a Circle object in model space and
    ' adds a new Hyperlink to its Hyperlink collection
    Dim Hyperlinks As AcadHyperlinks
    Dim Hyperlink As AcadHyperlink
    Dim circleObj As AcadCircle
    Dim centerPoint(0 To 2) As Double
    Dim radius As Double
    Dim HLList As String
    ' Define the Circle object
    centerPoint(0) = 0: centerPoint(1) = 0: centerPoint(2) = 0
    radius = 5#
    ' Create the Circle object in model space
    Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPoint, radius)
    ThisDrawing.Application.ZoomAll
    ' Get reference to the Circle's Hyperlinks collection
    Set Hyperlinks = circleObj.Hyperlinks
    ' Add a new Hyperlink complete with all properties
    Set Hyperlink = Hyperlinks.Add("AutoDesk")
    Hyperlink.URL = "www.autodesk.com"
    Hyperlink.URLDescription = "Autodesk Main Site"
    Hyperlink.URLNamedLocation = "MY_LOCATION"
    ' Read and display a list of existing Hyperlinks and
    ' their properties for this object
    For Each Hyperlink In Hyperlinks
    HLList = HLList & "____________________________________" & vbCrLf
    ' Separator
    HLList = HLList & "URL: " & Hyperlink.URL & vbCrLf
    HLList = HLList & "URL Description: " & Hyperlink.URLDescription &
    vbCrLf
    HLList = HLList & "URL Named Location: " &
    Hyperlink.URLNamedLocation & vbCrLf
    Next
    MsgBox "The circle has " & Hyperlinks.count & " Hyperlink: " & vbCrLf &
    HLList
    End Sub"GhysBoy" wrote in message
    news:5463325@discussion.autodesk.com...
    Laurie Comerford
    CADApps
    www.cadapps.com.au
    Hi all,
    Ghyslain Baril
    06-07-2010 05:50 AM in reply to: *Laurie Comerford
    hi,
    can anyone suggest .net code to add a new hyperlink to a polyline?
    andrea
