AutoCAD 2007/2008/2009 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
express tools wont load
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
today for no apparent reason express tools will not load . autocad behaves as if they are not installed .
they has always worked ok before that
does anyone have an idea why this happened
and is there a fix without reinstall from cd ? thank you
Re: express tools wont load
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
verify the supportpaths (that one of the paths points to the ExpressTools folder) and verify if the menu ACETMAIN is loaded.
BTW:
what info do you see (that we don't see) that makes you thinking that?
- alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
any express command says " no function definition"
support path are ok
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Check the DEMANDLOAD variable (Set it to 3)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
>> support path are ok
And looking with the Windows-explorer into the folder to which the support-path points ==> does this folder exist and are there file in it?
- alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
thanks to you both . i haven tried DEMANDLOAD as i read the message too late . I might try next week .
i dont believe the issue is related to content of support folder . (besides, it is normal) . to my knowledge acetmain.cui has graphic interface , not core commands.
what i did finally was switch to another session : then expresstools loaded .
but some of acad behaviour was strange . Adcenter and toolpalettes windows were sort of difficult to move even though LOCKUI is set to 0 .
I am starting to think this is an issue with this pc. on any session system gives error messages, and i am unable to load profiles because of registry error .
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
In that case try to repair (or if needed uninstall and reinstall) AutoCAD.
- alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
DEMANDLOAD was set to 3 .
