• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    Valued Mentor
    express tools wont load
    283 Views, 7 Replies
    01-10-2013 02:28 AM
    today for no apparent reason express tools will not load  . autocad behaves as if they are not installed .
    they has always worked ok before that
    does anyone have an idea why this happened
    and is there a fix without  reinstall from cd ?   thank you
    Please use plain text.
    Re: express tools wont load
    01-10-2013 03:33 AM in reply to: mrkaplan
    verify the supportpaths (that one of the paths points to the ExpressTools folder) and verify if the menu ACETMAIN is loaded.
    BTW:
    what info do you see (that we don't see) that makes you thinking that?
    - alfred -
    Alfred NESWADBA
    Valued Mentor
    01-10-2013 04:26 AM in reply to: alfred.neswadba
    any express command says " no function definition"
    support path are ok
    Patchy
    01-10-2013 04:37 AM in reply to: mrkaplan
    Check the DEMANDLOAD variable (Set it to 3)
    >> support path are ok
    And looking with the Windows-explorer into the folder to which the support-path points ==> does this folder exist and are there file in it?
    - alfred -
    Alfred NESWADBA
    Valued Mentor
    01-12-2013 02:40 AM in reply to: alfred.neswadba
    thanks to you both . i haven tried DEMANDLOAD as i read the message too late . I might try next week .
    i dont believe the  issue is related to content of support folder . (besides, it is normal) .  to my knowledge acetmain.cui has graphic interface , not core commands.
    what i did finally was switch to another session  : then  expresstools loaded .
    but some of acad behaviour was strange .  Adcenter and toolpalettes windows were sort of difficult to move even though LOCKUI is set to 0 .
    I am starting to think this is an issue with this pc.  on any session system gives error messages,  and i am unable to load profiles because of registry error .
    01-12-2013 03:20 AM in reply to: mrkaplan
    In that case try to repair (or if needed uninstall and reinstall) AutoCAD.
    - alfred -
    Alfred NESWADBA
    Valued Mentor
    01-13-2013 10:47 PM in reply to: Patchy
    DEMANDLOAD was set to 3 .
