• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2007/2008/2009 DWG Format
    Active Member
    esc key not working
    341 Views, 3 Replies
    09-17-2008 11:02 AM
    hi,
    I'm trying to fix this problem but I couldn't find anything.
    My esc key is not working, I mean it doesn't cancel anything, it's like "dead". I downloaded trial versions of autocad architecture 2009, autocad 2009, and in both programs it starts working then after some minutes it's dead. If I reboot it starts working again, but for some minutes only. My keyboard works fine.
    I hope you can help me in some way. Which can be the origin of the problem? thanks a lot,
    dario
    Please use plain text.
    Valued Contributor
    Re: esc key not working
    09-17-2008 11:42 AM in reply to: dariocesare
    Does AutoCAD exit when you hit the "Q" key?
    wrote in message news:6033569@discussion.autodesk.com...
    hi,
    thanks a lot,
    dario
    Active Member
    09-17-2008 11:44 AM in reply to: dariocesare
    yes, when I press ctrl+q
    Active Member
    09-17-2008 11:45 AM in reply to: dariocesare
    I run vista ultimate 64 bit and autocad 2009 architecture
