• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    Active Contributor
    dimensions wrong in layout
    298 Views, 8 Replies
    09-30-2011 05:40 AM
    hello there,
    i am stumbling on a very strange problem that has never occurred until now.
    i want to set dimensions on a layout and all vertical dimensions seem to be wrong whereas the horizontal ones are ok. if i set dimensions in the paper-space they are ok either way. any idea what this could be?
    regards,
    bert
    Please use plain text.
    *Expert Elite*
    Betreff: dimensions wrong in layout
    09-30-2011 05:45 AM in reply to: bertbert
    >> seem to be wrong
    What is "wrong"? Color, lineweight, linetype, dimension-value, ...?
    If you can upload a drawing it would be great (and I think much faster to get a result).
    You tried _AUDIT to repair any problems within the DWG-database?
    You checked your dimension-style? You tried the same within another drawing?
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Active Contributor
    09-30-2011 05:57 AM in reply to: alfred.neswadba
    hi,
    it is the value of the dimention that is wrong. exp: a value that should be 175 appears as 173
    bert
    *Expert Elite*
    09-30-2011 06:06 AM in reply to: bertbert
    without seeing the drawing I would check:
    a) if I have used the object-snap points correctly
    b) if there has been any modification to the scale of the viewport
    - alfred -
    Alfred NESWADBA
    Active Contributor
    09-30-2011 06:32 AM in reply to: alfred.neswadba
    thanks for having a look!!!
    bert
    *Expert Elite*
    Patchy
    09-30-2011 07:24 AM in reply to: bertbert
    Because in this viewport you have a slight Z in the UCS.
    Try dimensioning it again in the new drawing.
    Active Contributor
    09-30-2011 07:34 AM in reply to: Patchy
    ok! thank you very much!!!
    how can i get rid of it? it doesn't show in the properties.
    bert
    *Expert Elite*
    Patchy
    09-30-2011 07:43 AM in reply to: bertbert
    Go into each viewport, and type in UCS, W  and then PLAN, Current to correct each viewport UCS.
    or copy the correct viewport and redo Zoom XP.
    Active Contributor
    09-30-2011 07:51 AM in reply to: Patchy
    thank you very much for your help!!!
    have a nice evening!
    best regards
    bert
