• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    Member
    deleting attributes from blocks
    747 Views, 4 Replies
    05-18-2010 02:59 PM
    New to the group, I've got several blocks with attributes in a base dreawing and want to remove all of the attributes but seem to have trouble removing them in mass. I've tried to rename the block and delete them but no go... So I've had to resort to exploding the attributes to text in express and remove them one at a time?
    Is there an easier way? could really use some help!!
    Please use plain text.
    *None
    Re: deleting attributes from blocks
    05-18-2010 03:10 PM in reply to: teggarfowd
    > Thanks
    So . . . do you want to keep the blocks? If so, then use BURST to
    explode the attributes to text.
    Member
    05-18-2010 03:41 PM in reply to: teggarfowd
    Yes I will keep the blocks and their existing layers, I have gone through and redifined the block and re-inserted them but the attributes are still there after a regen. I'd go and turn off the attributes from the modify-toolbar but need to see other attributes in my sheet sets.
    *mp
    05-18-2010 05:37 PM in reply to: teggarfowd
    are you wanting to permanently get rid of the attributes and the values they
    contain?
    you appear to not want the burst command effect that some mentioned.
    if so you can write a lisp or vb or whatever to loop through the block
    of interest and delete the attribute objects in those
    . as you learned redefining a block will not
    change existing block - (for the entities only)...
    attributes are unique in this respect compared to any other entity in a
    block definition.
    the block reference can have more or less attributes than the block
    definition itself.
    that is why you have to loop the block references, not the block definition,
    and remove the attributes from those references.
    hth
    mark
    wrote in message news:6393429@discussion.autodesk.com...
    *Kate M
    05-19-2010 04:49 AM in reply to: teggarfowd
    You need to use the Synchronize Attributes command (ATTSYNC) after modifying
    block attributes in order to see the effect of your changes.
    Kate Morrical
    AutoCAD LT Technical Marketing Manager
    http://blogs.autodesk.com/ltunlimited
    "teggarfowd" wrote in message news:6393429@discussion.autodesk.com...
