• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2007/2008/2009 DWG Format
    Active Member
    acad.pat
    342 Views, 5 Replies
    04-26-2008 09:41 AM
    I want to use my hatch patterns I had created/addled to on a previous version of AutoCAD (2002). Where do I locate the hatch pattern file (acad.pat). I looked every where but 2008 keeps showing the standard patterns
    Please use plain text.
    *A+P
    Re: acad.pat
    04-26-2008 10:03 AM in reply to: fred99
    That'll depend on how you added them onto AutoCAD 2002.
    If you added them in the acad.pat file then you'll have to look for this
    file from that previous version of AutoCAD and replace the one AutoCAD 2009
    is using.
    If you added them in separate files with extension type of .pat, then you'll
    need to copy all those .pat files into one of the folders in AutoCAD's
    search path.
    To locate where any version of AutoCAD finds acad.pat, at the command prompt
    type:
    (findfile"acad.pat")
    Paul
    "fpascal" wrote in message news:5916060@discussion.autodesk.com...
    > patterns
    Active Member
    Re: acad.pat
    04-26-2008 11:46 AM in reply to: fred99
    Thanks I did find the file, however I had made changes to it, but when using hatch, AutoCAD still shows the standard hatch palette not the new I want to use. AutoCAD still must be using another file located somewhere else other than the support directory.
    Where does AutoCAD store this file.
    *A+P
    Re: acad.pat
    04-26-2008 05:23 PM in reply to: fred99
    What I would try next is to edit the acad.pat file, copy & paste one of the
    custom hatch patterns into a new text file with the matching file name.
    For example, if the custom hatch pattern has a name called 3BRICK, the text
    file name should be 3BRICK.pat.
    Save 3BRICK.pat in a folder that is on AutoCAD's search path as listed under
    Options>Files tab>Support File Search Path
    Now execute the HATCH command and click on the ... button or double click on
    the Swatch pattern.
    Click on Custom tab and you should see 3BRICK.pat listed here.
    Paul
    "fpascal" wrote in message news:5916092@discussion.autodesk.com...
    Distinguished Contributor
    Re: acad.pat
    04-27-2008 09:26 AM in reply to: fred99
    I don't recommend modifying acad.pat due to potential data loss on an AutoCAD upgrade.
    Copy individual custom pat files to:
    %APPDATA%\Autodesk\AutoCAD ????\R??\language\Support
    They will automatically display on the custom tab of the hatch dialog.
    You mentioned hatch "palette". If you're using a palette instead of the hatch dialog, you're probably best off to create your own custom hatch palette.
    *Warren Trost
    Re: acad.pat
    04-28-2008 09:48 AM in reply to: fred99
    Obvious way is to keep a copy of the added data in a separate file to be
    able to add back in to the next version. Mine is 3519K. It does take a bit
    of time to use an added customized pattern though so they aren't used much
    from the picture selection method.
    wrote in message news:5916275@discussion.autodesk.com...
    AutoCAD upgrade.
    palette.
