• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    *Dean Saadallah
    Re: Z value with "CHSPACE"
    08-06-2008 06:41 AM in reply to: Kiwi Russ.
    Your paperspace content has a Z height, why?
    Your modelspace TARGET and EXTMAX variables list a Z elevation that matches
    everything you 'chspace' over there.
    Have not had the time to figure out why with your partial file.
    Dean Saadallah
    http://LTisACAD.blogspot.com
    Add-on products for LT
    http://www.pendean.com/lt
    Please use plain text.
    Distinguished Contributor
    08-06-2008 01:32 PM in reply to: Kiwi Russ.
    thanks guys yes that seems to be the problem.
    The question is why and how can I change the two read only system variables : "TARGET" and "EXTMAX"
    Maybe it may have something to do with the UCS?
    Russ
    *Dean Saadallah
    08-06-2008 02:25 PM in reply to: Kiwi Russ.
    EXTMAX is part of the 'extents' of your drawing, an indication you have an
    object there. Zoom All usually resets it if nothing is there, force a
    REGENALL perhaps.
    TARGET refers to a UCS coordinate referencing that point I believe, not sure
    how you reset that one.
    Dean Saadallah
    Member
    06-10-2009 10:59 AM in reply to: Kiwi Russ.
    Did you ever figure this out? I have the same issue. I notice that if my viewport is not twisted then it will not do it. Have you found this to be true?
    The fix
    10-05-2012 11:52 AM in reply to: *Dean Saadallah
    I know it has been a long time since this question was asked but I found out the solution. I just started using chspace and it was driving me nuts that Z values kept getting added to everything. You need to display your drawing in a front or side of whatever 3d view you want. Zoom extents. Find everything with Z values and get rid of the Z values. I had a couple blocks that had Z values.
    Russell
