• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2007/2008/2009 DWG Format
    Valued Contributor
    Undo command is disabled
    574 Views, 18 Replies
    03-21-2008 09:11 AM
    I've been having this problem for quite some time now. Every time I open a drawing, new or old, my u command is ALWAYS disabled! How can I correct this so it's automatically enabled whenever I open a drawing?
    Please use plain text.
    Re: Undo command is disabled
    03-21-2008 09:19 AM in reply to: DLAWSON
    it may just be,
    at the command line:
    undo
    control
    all
    Distinguished Contributor
    03-21-2008 09:20 AM in reply to: DLAWSON
    Old or new drawings make no diff.
    Redifine U for undo in Acad.pgp if it disabled.
    Valued Contributor
    03-21-2008 09:30 AM in reply to: DLAWSON
    I can turn it on if I use that method, but I have to do that every time I open a drawing. It's annoying.
    Valued Contributor
    03-21-2008 09:31 AM in reply to: DLAWSON
    The U command is valid, it is just disabled until I manually enable. This is what happens when I hit "u" in a drawing.
    Command: u
    U command disabled. Use UNDO command to turn it on
    Then I can type in "undo" and turn it on again, but why isn't it automatically enabled when it starts up?
    03-21-2008 09:41 AM in reply to: DLAWSON
    Try
    REDEFINE
    and see if it works
    *Murph
    03-21-2008 09:56 AM in reply to: DLAWSON
    Most likely you are running a lisp at start or one that is loaded at start
    up that has an "UNDO Function" in it that is not being reset property.
    Murph
    www.map3d.wordpress.com
    "Derek Lawson" wrote in message news:5882505@discussion.autodesk.com...
    Command: u
    Valued Contributor
    03-21-2008 10:00 AM in reply to: DLAWSON
    Well, I tried redefine and for the command I specified both "undo" and "u". Neither seemed to work. When i press "u" again I still get the disabled message.
    Valued Contributor
    03-21-2008 10:02 AM in reply to: DLAWSON
    How would I be able to find the lisp files that are automatically loaded?
    03-21-2008 10:06 AM in reply to: DLAWSON
    Tools>load application>Startup suite "contents" button
    Rob
