AutoCAD 2007/2008/2009 DWG Format
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: UCS, World, Viewport crosshair drawing rotation issue
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-23-2009 08:49 AM in reply to:
will2605
I'm not quite sure what you're after, but try Ucs > View. This will align the UCS and crosshairs with the viewport.
~~~Civil 3D 2008~~~
*A+P
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
will2605
Snapang = 0
Paul
wrote in message news:6223664@discussion.autodesk.com...
still not fixed!
Paul
still not fixed!
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-23-2009 09:01 AM in reply to:
will2605
sorted it!
rotated the drawings in modelspace and used snapang to determine the degree of the rotated cross hair..just selected the end points of a horizontal line in the drawing to correct the crosshair..
thanks to everyone for their help along the way!
persistence pays....
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-24-2009 05:12 AM in reply to:
will2605
Rotated the modelspace components?? ummm ... what is the current UCS, SNAPANG, VIEWTWIST and VIEWDIR?
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-24-2009 07:26 AM in reply to:
will2605
Ummmm ... you did what?
/shivers
DJ
/shivers
DJ
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-10-2010 07:19 PM in reply to:
will2605
i am having the same issue with autocad 2009 (i just googled my problem and found this thread). what happens is... set my UCS to world, viewing the model in an isometric view, and when i go to draw a polylin/rectangle/line/etc i can see the UCS rotates slightly (about 1 degree) about the X axis. so when i draw my line/shape... it is not sitting "flat"/"parallel" with the world UCS.
any help with this problem? wills solution does not work for me.
cheers.
cheers.
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-10-2010 07:52 PM in reply to:
will2605
after some more investigation... i think i have found that the reason the UCS was rotating itself is because of the auto align/align to face feature of the newer autocads. is there a way to disable this feature?
the feature im talking about is when i try to draw a polyline, the ucs will align itself with the face of a 3d solid i am hovering over.
any help would be greatly appreciated.
----SOLVED------
the problem was with the feature called "dynamic UCS". toggle this feature on/off with CTRL+D.
my dynamic UCS was aligning itself with a hidden item, so i was waving my cursor around my viewport watching the UCS change in all funky ways... aligning itself with faces of a 3D solid that was hidden... what a drag.
hope this could help a few folks out. Edited by: lamensterms on Jan 11, 2010 3:56 AM
----SOLVED------
