AutoCAD 2007/2008/2009 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Trim fonction problem
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Im working on autocad 2008 and i mess up some setting...
the function trim still work by command but where it use to be a button, theres now only a box with an '?' on it icon
and the button doesnt work anymore...
can someone help me?
thx!
Re: Trim fonction problem
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
try to get the original AutoCAD menu and copy it to that folder from the menu you currently use.
If just the icon shows the wrong image (or a question mark) it would have been just the resource file with the icons, but as you wrote that also the command behind the icon is defect I guess someone played with the menufile.
[EDIT]if you don't know where to find an original menufile then login with a new Windows-user accout to your system, start AutoCAD, and within the user-folder AutoCAD creates a default menu. That you can use to replace your defect one. [/EDIT]
If you have done any customizations to your AutoCAD then make sure to back them up before that changes.
Good luck, - alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Where those files are saved? I cant find them..
thank again
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
What os do you have?
If you search through
C:\USERS\<your login name>
for the file ACAD.CUI*
then verify first that your search includes hidden and system directories.
- alfred -
Alfred NESWADBA
