• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    Distinguished Contributor
    Tooltips w/ Purge dialog box
    107 Views, 2 Replies
    09-16-2008 12:16 PM
    Is there any way to keep the Tooltip from popping up while using the Purge dialog box? I’ve tried Tooltips and Rollover settings but I can’t seem to make it stop.
    Thanks.
    Please use plain text.
    *Chris
    Re: Tooltips w/ Purge dialog box
    09-16-2008 03:56 PM in reply to: Kali_
    OK this is strange. I set "tooltips" to "0" and it doesn't stop the tool
    tips. If I exit ACAD and go back in "tooltips" is still set to "0" and the
    tool tips are disabled. Now if I have "tooltips" on (set to "1") and I turn
    off "tool tips" via the options dialog box (under the "Display" tab) "Tool
    tips" are instantly disabled. Long story short (I know too late for that)
    turn off "Tool tips" via the "Options" command to get instant gratification
    (or sumtin like that).
    Chris
    wrote in message news:6032693@discussion.autodesk.com...
    dialog box? I've tried Tooltips and Rollover settings but I can't seem to
    make it stop.
    Thanks.
    09-17-2008 07:48 AM in reply to: Kali_
    Thanks Chris for getting that box out of my face. That is odd that the command line doesn’t work the same as the Option box. Honestly I don’t remember, but I doubt if I even tried the dialog box version of setting the variable. But as long as it works I’m good to go. Thanks again,
    Kali
