AutoCAD 2007/2008/2009 DWG Format
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Tool Palette problem
- Highlight
- Email to a Friend
My docked tool palette has worked for a long time. In the last few days, when I go to pick the
blocks, they are visual in the palette, but I am not able to drag to drawing? Is there some setting
that was changed that does not allow selecting and dropping into drawing?
Re: Tool Palette problem
- Highlight
- Email to a Friend
when you double click on the icon ... what happens?
when you try to drag&drop ... do you get a message in the command-line?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
- Highlight
- Email to a Friend
In the command line , it says, block " name " not found.
- Highlight
- Email to a Friend
So my first guess is: the drawing, where the block-definitions come from, has been moved or deleted. Behind every block-item in the palette there is defined where to get the block-definition (a DWG-file where this block is defined). If this drawing is not at the location/the folder where it was at the time you defined the palette, this error raise up.
- alfred -
Alfred NESWADBA
- Highlight
- Email to a Friend
Yes, good point, I did rearrange alot of files recently and maybe misplaced. It may take a fews days till I get to this.
I will let you know how it works out. Thanks.
- Highlight
- Email to a Friend
I had the same problem. I started using the command WBLOCK instead of BLOCK. The difference is that the command BLOCK creates the block in the drawing that you are working with at the time. WBLOCK creates a drawing block in the a directory that you specify and with that you can create a tool pallete by using DesignCenter.
