• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2007/2008/2009 DWG Format
    Text to Mtext
    251 Views, 6 Replies
    03-15-2012 09:37 AM
    I have received a large text in text format. I have converted the lines in MTEXT. Now, I am trying make one Mtext. I was trying to copy paste on the first Mtext and the paste is not working. MY intention is to make one MTEXT file and then make columns to fit in my paper space. How do I add different MTEXT to one MTEXT file? I have attached the file of reference.
    Please use plain text.
    pendean
    Re: Text to Mtext
    03-15-2012 10:04 AM in reply to: apanbasu
    Seems to work just fine here: are you "selecting all" inside the first MTEXT before you CTRL+C?
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Re: Text to Mtext
    03-15-2012 10:41 AM in reply to: apanbasu
    I am copying all other Mtext then opeing the first one as ddedit and then trying to paste the copied metexts. I am running 2008. I tried one at a time also.
    pendean
    Re: Text to Mtext
    03-16-2012 05:54 AM in reply to: apanbasu
    Did you see the file I posted? I did what you want and it worked fine: but you have to do one MTEXT at a time, open the source, select all then CTRL+C, then open the destination, scroll down, select the location and CTRL+V.
    The method you describe is from a fantasy, not real-life AutoCAD or Windows, unless you are trying to rely on some third party clipboard manager tool (which is failing if you actually have one).
    Re: Text to Mtext
    03-16-2012 06:50 AM in reply to: apanbasu
    I was not using ctrl-C and Ctrl-V. I was trying to use copy from EDIT and /paste from the ACAD window. I am sorry I missed your corrected file. An Architect friend of mine helped to get the files in order. Thanks for your help..
    Distinguished Mentor
    Re: Text to Mtext
    03-18-2012 03:55 PM in reply to: apanbasu
    If you want all the text in one MTEXT block, get all the text/mtext in order and explode it all to text.
    Then just select all the text and convert it to MTEXT using the txt2mtxt command (part of the Express Tools suite).
    You may have to go through and add line breaks, carriage returns and so on to get it to a reasonable state.
    You may also wish to check out the options available as well.
    Regards Brad
    Icemanau (NNTP handle: Brad Coleman)
    You may recognize me from the
    hundreds of previous newsreader posts
    I've made over the last 5 years
    as Brad Coleman
    Re: Text to Mtext
    03-18-2012 07:22 PM in reply to: apanbasu
    An Architect friend of mine helped top get all texts in one mtext. However, I will try to remember the suggestion for the future
