• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    Member
    da.chisel
    Accepted Solution
    Text auto-rotate problem
    2511 Views, 7 Replies
    05-19-2011 06:51 AM
    I am having a problem with inserting/editing text in simple 2D cad drawings :
    When I click on MTEXT, my cursor changes to the usual text box insertion icon, but the text appears vertical (as if rotated 90º). And entering text (no matter how big or small the MTEXT box is) the text also appears vertical.
    When I try to edit text from older drawings (done prior to having this problem), the same problem occurs : The text changes orientation and goes vertical.
    I have to manually rotate the text back to the horizontal position every time, and it is annoying.
    This is a problem that started occuring in the past week (no changes that I know of were made to autocad settings).
    Help please!
    Please use plain text.
    *Expert Elite*
    Patchy
    Re: Text auto-rotate problem
    05-19-2011 07:19 AM in reply to: da.chisel
    Attach your drawing here, let's take a look.
    Member
    da.chisel
    05-19-2011 07:23 AM in reply to: Patchy
    Here it is..
    *Expert Elite*
    Patchy
    05-19-2011 07:33 AM in reply to: da.chisel
    Never use the @Arial...  Use the Arial instead.
    Member
    da.chisel
    05-19-2011 07:51 AM in reply to: Patchy
    Thank you :smileyhappy: This solved my issue.
    New Member
    daffouk
    02-20-2012 06:49 AM in reply to: da.chisel
    Thanks for this answer, it solved my rotating text problem too
    Dave
    *Expert Elite*
    heinsite
    02-25-2012 03:28 PM in reply to: Patchy
    >... Never use the @Arial... ...<
    ... Unless you specifically *want* your text rotated 270 degrees that is.  And sometimes you just might.
    All of the "@" fonts will do this btw.  Not just @Arial.
    Dave
    Dave Hein, P.E.
    *Expert Elite*
    JGerth
    03-02-2012 12:24 PM in reply to: heinsite
    begs the question....what are the @something fonts?  I _only_ see them in Acad, never observed them in any other application.  and they seem to proliferate...
    Edited by
    Discussion_Admin
