• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2007/2008/2009 DWG Format
    Valued Contributor
    amflasf
    Text Not Recognized
    219 Views, 18 Replies
    10-04-2012 09:17 AM
    Our titleblock file on one of the computers in the office is not recognizing the correct font styles.
    The fonts are loaded but obviously something is not being recognized because it should not extend outside the parameters of the titleblock. Other machines don't have this issue. Anyone know what I need to do to get this to be corrected on the one machine?  See attached.
    Thanks.
    Please use plain text.
    *Expert Elite*
    pendean
    Re: Text Not Recognized
    10-08-2012 10:02 AM in reply to: amflasf
    The one machine has the wrong font installed: fonts are external to the program, they are not embedded in files.
    Match up all the fonts.
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
    Valued Contributor
    amflasf
    10-08-2012 10:06 AM in reply to: amflasf
    All fonts are already installed and that fixed the logo situation.
    It's now just the content of the titleblock that is still messed up.
    I can't figure out why. When I hit F2 it doesn't indicate any substitution for the font so I don't know why there is an issue.
    Please advise further. Thanks!
    *Expert Elite*
    pendean
    10-08-2012 11:19 AM in reply to: amflasf
    Define "content of the titleblock that is still messed up" in more detail please: and what object types are they, FIELDS or ATTRIBUTES or just TEXT?
    Valued Contributor
    amflasf
    10-08-2012 09:26 PM in reply to: pendean
    Content of Titleblock - where it says project name, drawing title, sheet.
    They are set up as an Attribute.
    Hope this helps with some additional thoughts on what I need to do to get it to work.
    Thanks!
    Valued Contributor
    amflasf
    10-09-2012 08:52 AM in reply to: amflasf
    To followup on my previous reply, I checked the attribute and exploded it to see if it would register our font.
    Everything seems to be registered correctly our text style matches the font that is loaded into the computer. Nothing seems to be substituted.
    Further thoughts?
    *Expert Elite*
    pendean
    10-12-2012 05:56 AM in reply to: amflasf
    You'll have to share a DWG file if you can.
    Valued Contributor
    amflasf
    10-12-2012 09:31 AM in reply to: pendean
    Ok. Here it is, I've etransmitted it all so you have the full deal.
    Thanks!
    *Expert Elite*
    pendean
    10-12-2012 02:14 PM in reply to: amflasf
    You did not include the fonts, so the problem is replicated here and most likely the real issue with your user/titleblock.
    Valued Contributor
    amflasf
    10-12-2012 02:29 PM in reply to: pendean
    oh sorry i thought those would come through with the etransmit.
    here's everything.
    yes, it looks like that on my coworkers machines when they open the titleblock but all the fonts are loaded.
    that's what is confusing.
