• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    TRIAL VER. 2009 NOT LOADING ON VISTA
    117 Views, 17 Replies
    04-11-2008 07:17 AM
    ANY IDEAS ON 2009 TRIAL STOPPING ON OPENING? RUNNING ON VISTA. DO I NEED A PATCH?
    Please use plain text.
    Valued Contributor
    Re: TRIAL VER. 2009 NOT LOADING ON VISTA
    04-11-2008 08:01 AM in reply to: mcheney
    are you running 64bit vista and trying to install the 32 bit trial?
    04-11-2008 08:45 AM in reply to: mcheney
    THANKS I'LL D.L. THE 64 AND TRY AGAIN
    04-11-2008 09:26 AM in reply to: mcheney
    NO LUCK. MY SYSTEM IS 32. ANY OTHER IDEAS
    Valued Contributor
    04-11-2008 09:28 AM in reply to: mcheney
    that was my only thought, do you meet all the other requirements?, what do you mean by it stops? I have not installed it on Vista, I have XP
    04-11-2008 09:35 AM in reply to: mcheney
    It loads partly. the camand line shows it looking under user directory for dwt file to load. then it locks. I thought those file are under the acad dir. ???
    *Owen Wengerd
    04-11-2008 10:50 AM in reply to: mcheney
    It's not locked up, it's just having trouble connecting to Autodesk's
    server. Just wait, it will eventually time out and continue to load. :smileyhappy:
    Owen Wengerd
    President, ManuSoft <>
    VP Americas, CADLock, Inc. <>
    "mcheney" wrote in message news:5902114@discussion.autodesk.com...
    dir. ???
    04-14-2008 08:35 AM in reply to: mcheney
    Good Day Owen
    Unistalled & reinstalled I've tried to run program and let it time out. 10 min. still no time out. this is the error mess. that opens
    Application: AutoCAD Version: C.56.0 Error: Unhandled Exception
    any ideas
    Thanks Mike
    Valued Contributor
    04-14-2008 09:42 AM in reply to: mcheney
    mcheney,
    Is your ribbon showing? If not you may have the wrong .net version installed.
    Hope this helps,
    Randy Young
    AutoCAD Test Development
    04-14-2008 09:46 AM in reply to: mcheney
    Good Day Randy
    What do you mean by ribbon.
    Thanks Mike
