• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2007/2008/2009 DWG Format
    New Member
    Specify Displacement
    111 Views, 3 Replies
    07-20-2012 07:07 AM
    Good morning, if there is anyone who can help, I use AutoCAD 2007. When I go to move something, either in model, or, paper space the object is automaticlly set to 0,0,0. And when I hit enter that where the object goes. I have tried to use "Control D" command to turn "Dynamic UCS"  off or on, that doesn't work either. If anyone can help, thanks and have a great day.
    Please use plain text.
    *Pro
    scot-65
    Re: Specify Displacement
    07-20-2012 03:04 PM in reply to: Bayouboy637
    For the MOVE command and others, after selecting the objects, you have to specify a
    beginning point by selecting a point on the screen with your mouse. If you do not, it will be 0,0.
    The only other thing I can think of is when you hit [Enter] after selecting the objects,
    your keyboard is sending out [Enter][Enter], which seems to me this is what you are describing.
    New Member
    09-11-2012 09:07 AM in reply to: Bayouboy637
    Did you figure this out?  I have the same problem and it drives me crazy!
    *Expert Elite*
    09-12-2012 10:43 AM in reply to: pbutler
    Keep in mind that somewhere along the line relative became default rather than absolute.
    relative @
    absolute #
