• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    Active Contributor
    Reverse Revision Cloud
    1090 Views, 2 Replies
    07-12-2008 06:26 AM
    Does sombedy have a lisp code that automatically reverse or inverse after creating a revision cloud. I mean without using the mouse right click.
    Please use plain text.
    Distinguished Contributor
    Re: Reverse Revision Cloud
    07-15-2008 08:23 AM in reply to: ajustin
    isnt that an option of the command?
    *Bill DeShawn
    07-16-2008 08:24 PM in reply to: ajustin
    Yes. It is. However, it's only present if you select an object by which to
    make the cloud. So, this is what you do. Run the command again, select the
    Object option, select the existing backwards cloud and when asked to reverse
    the direction, type Y for yes.
    _________________________
    Bill DeShawn
    bdeshawn@nospamsterling.net
    http://my.sterling.net/~bdeshawn
    Notice: New LISP tool for Landscape
    Design and for ATTEXT users.
    Measure and Divide with attributes!!
    wrote in message news:5981772@discussion.autodesk.com...
