• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    JonnyM32
    Re: Remove unreferenced .jpg from x-ref manager in AutoCAD 2008 LT
    06-29-2011 08:55 AM in reply to: Patchy
    no for example the drawing i am in now:
    i have attached another image in where you can see the full name of the jpg
    Please use plain text.
    Patchy
    06-29-2011 09:00 AM in reply to: JonnyM32
    Never a problem to detach any image for me
    Valued Contributor
    06-29-2011 09:06 AM in reply to: Patchy
    try the command "CLASSICXREF" if it appears & detach is available then use that
    JonnyM32
    do you have full Autocad??
    this is what mine comes up as...
    also this did show in a previous image i done using classicimage command
    JonnyM32
    06-29-2011 09:09 AM in reply to: ossmo02
    nope doesnt appear in there either ??
    Valued Contributor
    06-29-2011 09:13 AM in reply to: JonnyM32
    how large is the file? is it confidential?
    JonnyM32
    06-29-2011 09:23 AM in reply to: ossmo02
    its not just one drawing, its many, but they are around 250KB
    Valued Contributor
    06-29-2011 09:25 AM in reply to: JonnyM32
    So far the only option I have seen is to Wblock it to a new drawing. If it was 1 print I could do it for you.
    JonnyM32
    06-29-2011 09:33 AM in reply to: ossmo02
    yep that worked in getting out the jpeg, thank you for that.
    the only problem i am having with the same drawing is that when i open it, it is still looking for something and i am not sure what.  see image i am not sure how to stop this from coming up and just the drawing open???
    do you know anything about that??
    Valued Contributor
    06-29-2011 11:10 AM in reply to: JonnyM32
    I've only ever seen .shx file to be font files in which case you need to get the font from the original source, however it appears to be a shape file not a font.  take a look here
    http://forums.augi.com/showthread.php?t=32333
    http://forums.augi.com/showthread.php?t=31549
