• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    JonnyM32
    Accepted Solution
    Remove unreferenced .jpg from x-ref manager in AutoCAD 2008 LT
    1262 Views, 27 Replies
    06-29-2011 08:11 AM
    Does Anyone know how to remove Unreferenced .jpg From the x-ref Manager. in AutoCAD 2008 LT
    Everytime i open drawings it looks for things that arent there and therefore slows the drawing down.
    any ideas??
    Please use plain text.
    *Expert Elite*
    Patchy
    Re: Remove unreferenced .jpg from x-ref manager in AutoCAD 2008 LT
    06-29-2011 08:24 AM in reply to: JonnyM32
    Detach it.
    JonnyM32
    06-29-2011 08:26 AM in reply to: Patchy
    if it was as easy is that do you think i would have posted on the forum.
    it has unload or reload, and whichever one you select it does nothing as its not referenced to anything.
    any more suggestions???
    *Expert Elite*
    Patchy
    06-29-2011 08:32 AM in reply to: JonnyM32
    Wow, did I say detach it, or I said unload it ?
    JonnyM32
    06-29-2011 08:34 AM in reply to: Patchy
    well thank you for all your helpful information, i though forums were for help not sarcasm.
    *Expert Elite*
    Patchy
    06-29-2011 08:41 AM in reply to: JonnyM32
     " i though forums were for help "
    HOW MUCH MORE HELP DO YOU WANT?
    DETACH is different than UNLOAD
    JonnyM32
    06-29-2011 08:44 AM in reply to: Patchy
    yeah, do you read what i put there or not, When i press on unload it doesnt go anywhere it is still there,
    IT WILL NOT UNLOAD no matter how different it is, it is unreferenced there is no jpeg there, i want to remove it from the x-ref manager as when i open the drawing it is looking for an image that isnt there.
    DO YOU UNDERSTAND, DID YOU LOOK AT THE IMAGE I ATTACHED
    Valued Contributor
    06-29-2011 08:45 AM in reply to: JonnyM32
    It sounds like there may be an error in the OP's install if detach is not available.
    You should see this page;
    http://forums.autodesk.com/t5/AutoCAD-2007/Detaching-unreferenced-Images/m-p/1603831/highlight/true#...
    it may help your situation
    JonnyM32
    06-29-2011 08:52 AM in reply to: ossmo02
    thanks for your reply, i have looked at that article you provided and tried the command, but still nothing, i have attached some images for you to see.
    That might be a solution for full blown autocad where as i am looking for LT solution.
    *Expert Elite*
    Patchy
    The image name doesn't have [ ] would this caused a problem?
