• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    Remove missing shape file .shx
    10135 Views, 9 Replies
    05-23-2006 07:38 AM
    Someone sent me a regular .dwg file that must reference "scadline.shx" somewhere. It slows down the open for each file (12 files) because it wants me to specify the location of the .shx file upon open. The person who sent it to me does not know what it is and none of my in use text styles reference it. I've purged everything available. Any suggestions on how to remove this broken link, where the link may be, how to fool it by pointing to a different .shx file, or perhaps saving another .shx file as "scadline.shx"? I don't know how to do any of those, so if someone does, please let me know. Thanks.
    Please use plain text.
    *Tim Decker
    Re: Remove missing shape file .shx
    05-23-2006 07:45 AM in reply to: Tamilio
    Man, I would love something like this, I get sick of getting files with
    shape references in them, and no shape files to be found.
    *Murph
    05-23-2006 07:56 AM in reply to: Tamilio
    See this
    http://rkmcswain.blogspot.com/2006/02/select-shape-file.html
    Murph
    http://mappingitout.blogspot.com/
    wrote in message news:5183195@discussion.autodesk.com...
    *TRJ
    05-23-2006 08:07 AM in reply to: Tamilio
    I have recently discovered that sometimes it's looking for a "big" font. Use
    the STYLE command and check each text style defined in the dwhg. Uncheck,
    Use Big Font. This will eliminate the search in some cases.
    Distinguished Contributor
    05-23-2006 05:57 PM in reply to: Tamilio
    Good point, TRJ. Only problem with unchecking big font is that some people use the bigfont feature for keyboard accessible special characters. Might muck up some other things
    Same basic problem, not sending all the goodies along with the drawing.
    *R.K. McSwain
    05-24-2006 05:30 AM in reply to: Tamilio
    Tamilio said the following on 5/23/2006 9:38 AM:
    > Thanks.
    BTW: "scadline.shx" is a shape file used in Carlson products (SurvCADD,
    Carlson Survey, etc)
    As Murph said, see
    http://rkmcswain.blogspot.com/2006/02/select-shape-file.html for some ideas.
    R.K. McSwain
    New Member
    03-16-2010 02:49 AM in reply to: Tamilio
    I got the same problem but I've solved it. Hope this attached can help.
    cheers.
    Member
    05-09-2011 01:51 PM in reply to: Tamilio
    go here and download the file http://update.carlsonsw.com/kbase_main.php?action=display_topic&topic_id=538
    save and point to it when asked for it
    Member
    12-20-2012 09:15 AM in reply to: Tamilio
    DOWNLOADED, PROBLEM SOLVED.
    Member
    12-20-2012 09:16 AM in reply to: Tamilio
    SCROLL DOWN TO 3-16-2010 AND DOWNLOAD THE .SHX FILE.  PROBLEM SOLVED.
