• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    New Member
    Problems with copy and paste from different files
    388 Views, 7 Replies
    09-21-2012 01:50 AM
    Hi everyone,
    I've got some problems using copy and paste command for copy objects from different files.
    Sometimes the operation take me just few seconds, sometimes (say the 70% of the times) take me more than 20mins....and it's so frustrating and boring!
    I've read that could be a ram problem, but the pc is new!
    I've also try to use Scalelist command, but it doesn't work......Autocad says to me that there is a "error in the system"
    what can I do?I'm using an Autocad2008 version on Windows7, could be possible have a "conflictual problems" between the 2 systems?
    Thank you for your helping
    Please use plain text.
    *Expert Elite*
    pendean
    Re: Problems with copy and paste from different files
    09-21-2012 05:22 AM in reply to: zizi.goletta
    win7 is not supported for R2008, so yes that is a big deal, it means no one is trying to fix any issues.
    But, that should not happen unless the content of your drawings are the trigger: by chance can you post a DWG with this exact problem for someone here to try?
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    New Member
    09-21-2012 06:03 AM in reply to: pendean
    That's the point, win7 is not create for support cad2008..It's like I was suppose!
    No don't worry, now that I discover the problem I'll use another pc :smileyhappy:
    But anyway thank u so much!
    Best regards
    10-01-2012 09:21 AM in reply to: zizi.goletta
    10-12-2012 07:03 AM in reply to: zizi.goletta
    Im working on 2008 CAD and simple copy and paste in the draing takes forever. I tried the lisp command but nothing changed. still have to wait for simple copy and past... whats up with this?
    10-12-2012 07:04 AM in reply to: anoopvarrghese009
    Im on Win XP 64bit
    10-12-2012 08:42 PM in reply to: zizi.goletta
    Command: -SCALELISTEDIT
    Reset, Enter
    Yes, Enter
     Exit
    Do this steep in Both Drawing.
    Then Try.
        This command available Auto Cad 2008 and above only
    http://lispandtips.blogspot.com/2012/10/copy-and-paste-from-different-files.html
    Distinguished Mentor
    10-15-2012 07:28 PM in reply to: anoopvarrghese009
    I've recently upgraded the computer I use and it came with Win 7 Professional 64 bit. To install ACAD 2008, I used the XP Mode which sets up a virtual machince running XP. I then installed ACAD into this virtual machine so I have the better OS running for everything else and ACAD running in the old 32 bit OS with no conflict issues. Althoug I do have to find the latest accepted video card list from Autodesk and install it for the performence settings to work properly.
    Regards Brad
    Icemanau (NNTP handle: Brad Coleman)
    You may recognize me from the
    hundreds of previous newsreader posts
    I've made over the last 5 years
    as Brad Coleman
