• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    Active Member
    S_G_I
    Problem with a layer inserted to the drawing
    128 Views, 2 Replies
    12-02-2012 08:22 PM
    I have a weird problem with my drawing.
    It's a drawing of a newer version which I converted to 2007.
    Conversion was successful.
    I inserted my drawing as a BLOCK. Again, was successful.
    Then tried to plot and couldn't see my drawing at the PREVIEW.
    It just disappeared. I checked all the layers.
    All of them were ON for plotting, none disabled.
    What could be the explanation for this?
    Could anyone help?
    Thank a lot,
    S_G_I
    Please use plain text.
    *Expert Elite*
    Re: Problem with a layer inserted to the drawing
    12-03-2012 01:16 AM in reply to: S_G_I
    run command _AUDIT or open this drawing with command _RECOVER, both will verify the consisteny of the database.
    If that does not make anything better then try to save this drawing back to a DWG2000 or DXF14 format (I hope you don't loose any objects at this transformation, but that may disable some of the options you have from the newer inserted DWG-format).
    HTH, - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Active Member
    S_G_I
    12-03-2012 07:50 AM in reply to: S_G_I
    Thank you very much.
    I'll try and see what happens.
    S_G_I
