• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    Valued Contributor
    Accepted Solution
    Polyline grip - move to entered distance?
    335 Views, 2 Replies
    06-28-2012 11:27 AM
    Hello All,
    We recently got new computers and had to install ACA 2008 again and little by little have been tweaking the settings to get them back to what we had before on our old machines.  One thing that I can't seem to figure out how to correct is some setting for adjusting polyline grips.
    I used to be able to select a polyline, click on a grip point, and move the cursor in the direction I wanted and type in a distance I wanted it to move and hit enter and the grip would move that entered distance.  But now, when I do all that and enter a distance, the grip inturprets that distance entered as what the length of the PL segment is and shrinks or enlarges to that dimension I entered.
    I'm sure this is a quick and easy fix, just don't know where to fix it at.  Can anyone help me out?
    Thanks.
    Please use plain text.
    *Expert Elite*
    pendean
    Re: Polyline grip - move to entered distance?
    06-29-2012 07:16 AM in reply to: dficarra
    Do you have running osnaps on? Turn them of and try again.
    Is DYN on? Turn it off and try again.
    Which worked and which did not?
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Valued Contributor
    06-29-2012 09:03 AM in reply to: pendean
    Dean,
    Turning the DYN off while keeping the OSNAP on did the trick.
    Thanks!
