• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    New Member
    Plotting problem - Blocks with gradient fill prints when layer is off
    617 Views, 3 Replies
    03-12-2012 07:11 PM
    Hello All
    We have come across a strange problem using Gradient fill in blocks.
    In the attached drawing are two test blocks.
    The left hand blue block has a blue hatch pattern on the Hatch layer
    The right hand magenta block has a magenta gradient pattern the Gradient layer.
    If you turn off the Hatch and Gradient layers then the blue and magenta sections of the blocks are no longer displayed, this is correct.
    But if you plot or plot preview the drawing the magenta gradient is now visible and yes it does print, this is not correct.
    Finally if you explode both blocks and turn off the hatch and gradient layers it will correctly display on the screen and plot preview correctly (i.e no magenta or blue), this is correct.
    So the gradient will print correctly if it's a separate object but not if it's part of a block but the hatch has no problem in either case.
    I can get around the problem by turning off the plotting for the layer in the Layer properties manager but I should be able to do the same by simply turning off the layer itself.
    We have tried this on other versions of Autocad (2006, 2007) and the same problem happens.
    Does anyone have any ideas why this happens? The only thing I can think may be related to the problem is that the gradient colours are set in the Gradient dialog box and not controlled by the layer properties itself.
    I've done a searchof this site (and others) but I can't find any reference to a similar problem.
    Thanks for your help.
    Please use plain text.
    CADbloke
    Re: Plotting problem - Blocks with gradient fill prints when layer is off
    11-03-2012 04:08 AM in reply to: Iandj
    Confirmed this also happens in AutoCAD 2013. Looks like a bug.
    11-03-2012 05:43 AM in reply to: Iandj
    freeze the layers instead of switching them off.
    - alfred -
    Alfred NESWADBA
    01-09-2013 10:44 AM in reply to: alfred.neswadba
    I have a similar problem with Gradient hatches on turned off layers still plotting. Nothing else on the layers plot, just the gradients. Freezing the layer isn't an option since we are printing labels from within a block, that are on a separate labels layer, and freezing the layer will turn off the entire block.
    Can anyone confirm if this is a bug or if there is a workaround that doesn't involve revamping all of our layers on blocks?
    For those that don't have the problem I have, I can confirm that freezing the layers will make the gradients not plot.
    JB
