• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    Active Member
    Patent Drawing on AutoCAD 2008?
    262 Views, 4 Replies
    10-11-2007 10:48 PM
    I'm seriously considering purchasing AutoCAD 2008 to use as my primary drafting software. I've searched for what was previously said about patent illustration, but the threads were quite dated (5-7 years ago), and I'm not sure if what was said then is still true today. What I want to ask is:
    1. Considering that up till now most of my work has been tracing, should I get (A) AutoCAD 2008, or (B) AutoCAD 2008 LT? I think I'll still need to use the modeling aspect of AutoCAD for my work, so I'm undecided between the two.
    2. Should I use AutoCAD, or could I use another Autodesk brand product for my patent illustration needs?
    Please use plain text.
    *Laurie Comerford
    Re: Patent Drawing on AutoCAD 2008?
    10-12-2007 01:06 AM in reply to: pbyrnej
    The best way is to get LT and see if it does what you need. If it proves
    inadequate, upgrade it to the full AutoCAD. Any learning of LT will be
    directly useable in the full version.
    Check with your local dealers what the economics are.
    Laurie Comerford
    CADApps
    www.cadapps.com.au
    www.civil3Dtools.com
    wrote in message news:5747741@discussion.autodesk.com...
    two.
    *Dean Saadallah
    10-13-2007 01:48 PM in reply to: pbyrnej
    Have you looked at cheaper, easier to use CAD programs? AutoCAD has a
    steep learning curve... . Start downloading and trying demos of them
    all, you need to find what you are comfortable using and willing to
    spend time using.
    Dean Saadallah
    http://LTisACAD.blogspot.com
    Add-on products for LT
    http://www.pendean.com/lt
    10-13-2007 05:12 PM in reply to: pbyrnej
    You might have your local reseller demonstrate some of the other Autodesk products. I'm not sure AutoCAD will work very well for typical patent type drawings.
    10-13-2007 05:16 PM in reply to: pbyrnej
    The original Inventor Model from which Inventor Studio created the illustration.
