• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    *Phil Clark
    Object Cycling in Selection (overlapping objects)
    246 Views, 3 Replies
    04-14-2008 08:46 AM
    Changed in 2009 to SHIFT+SPACE from CTRL+Click. I'm trying to get used to
    the change, but it seems pretty cumbersome when used inside a command:
    1. You still have to click to select after highlighting desired object.
    2. If mouse is moved even slightly, hightlighting goes back to "default"
    object.
    3. I kept thinking it wasn't working, but realized I wasn't letting go of
    SHIFT before clicking to selecting (thus "removing" with shift).
    It's a little easier if you are selecting before issuing command.
    I've noticed that CTRL+Click doesn't do anything now (other than display
    little help dialog on using SHIFT+SPACE), anyone know the reason for the
    change? Any way of restoring CTRL+Click?
    Please use plain text.
    Distinguished Contributor
    Re: Object Cycling in Selection (overlapping objects)
    04-14-2008 12:52 PM in reply to: *Phil Clark
    If Legacyctrlpick is still available, set it to 1.
    Please, Please still be available.
    *Phil Clark
    04-14-2008 01:51 PM in reply to: *Phil Clark
    wrote in message news:5904092@discussion.autodesk.com...
    It is...thanks much! Guess I had changed in 08 and forgot
    04-14-2008 03:12 PM in reply to: *Phil Clark
    It is still available, but won't that set it back to before shift was used as well?
