• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    *Dilip Damle
    Not Trusted dwg warning even after saving
    233 Views, 21 Replies
    08-24-2007 10:07 PM
    Hello everyone,
    When you open a drawing savad by some other application
    you get the warning "This drawing was saved by an application
    not developed or licensed by Autodesk................."
    But after I save/saveas and close the Drawing from A2k8
    This message should not be shown the next time.
    But I can not get rid of this message. Is it normal?
    rgds
    Dilip Damle
    Life will be much easier if we just have a printout of
    all the commands that exist in Autocad kept handy.
    Please use plain text.
    *Matt Kolberg
    Re: Not Trusted dwg warning even after saving
    08-25-2007 11:13 AM in reply to: *Dilip Damle
    Look at tthe DWGCHECK variable to modify the warnings you get.
    Check out this link:
    http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=9078652
    Matt
    *Tony Tanzillo
    08-25-2007 02:05 PM in reply to: *Dilip Damle
    Can you post a copy of the file that causes
    AutoCAD to continue to display the FUD
    message, even after saving it in 2008?
    While I can't confirm it, I suppose it's
    possible that Autodesk did something like
    the educational 'virus', with files that were
    at some point in their life, written by non-
    Autodesk products.
    http://www.caddzone.com
    AcadXTabs: MDI Document Tabs for AutoCAD 2008
    Supporting AutoCAD 2000 through 2008
    http://www.acadxtabs.com
    "Dilip Damle" wrote in message news:5700772@discussion.autodesk.com...
    Hello everyone,
    rgds
    Dilip Damle
    Active Member
    08-26-2007 07:04 AM in reply to: *Dilip Damle
    Here is the file
    Distinguished Contributor
    08-26-2007 02:15 PM in reply to: *Dilip Damle
    Try running a recovery on the file.
    *Tony Tanzillo
    08-26-2007 04:14 PM in reply to: *Dilip Damle
    Did you try that, per chance?
    *Doug Broad
    08-26-2007 05:32 PM in reply to: *Dilip Damle
    That is strange. Auditing and recovering do not discover any errors. Purging and saving
    does nothing.
    The following choices will make the drawing appear safe but I am uncertain whether you
    will lose anything valuable that is hidden.
    1) Dxfout. Start a new drawing and dxfin.
    2) Start a new drawing. Insert the problem drawing (exploded).
    Strange that the application creating it made all the circles into splines. Nice looking
    drawing though.
    wrote in message news:5701247@discussion.autodesk.com...
    Here is the file
    *Gehenna
    08-26-2007 06:27 PM in reply to: *Dilip Damle
    Dilip Damle wrote:
    > Hello everyone,
    I Superpurged the dwg and copied and pasted and now do NOT get the
    warning. changed the name slightly. See the attached.
    *Tony Tanzillo
    08-27-2007 05:37 AM in reply to: *Dilip Damle
    Well, it certainly does seem to be
    'virus-like' behavior, because
    purging; recovering (which finds no
    errors), and saving in AutoCAD
    2008, does not change anything, and
    as per the screenshot
    below,
    the ObjectARX API is reporting that
    the file was not saved
    by
    Autodesk software.
    [img src="@164698"]
    Here is the
    file
    *Jim
    08-27-2007 06:51 AM in reply to: *Dilip Damle
    Autodesk does have a utility to convert files saved by other programs. DWG
    TrueConvert 2007. It seems to work - so far - for older drawings that I
    have saved using other programs.
