• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2007/2008/2009 DWG Format
    Distinguished Contributor
    Mtext error
    110 Views, 4 Replies
    04-11-2008 11:11 AM
    Apparently, if you don't install the multi-language dictionaries, every time you go to make an Mtext object, an error occurs which says "Unable to find main dictionary. Could not start speller." This is quite annoying, is there a way to suppress the message?
    Please use plain text.
    *Jimmy Bergmark
    Re: Mtext error
    04-11-2008 11:38 AM in reply to: thatcadguy
    Make sure to install the dictionaries seems to be the only way.
    Or you could simply copy the .dct files from the DVD to:
    C:\Program Files\AutoCAD 2009\Support
    But still it should not give this problem as there is an option to not
    install them.
    Jimmy Bergmark
    JTB World - CAD software, development and consulting
    Owner/Developer
    http://www.jtbworld.com
    http://blog.jtbworld.com
    Automate dimension notes in AutoCAD with DimNotes
    http://www.jtbworld.com/dimnotes.htm
    AutoCAD 2009
    http://www.jtbworld.com/autocad2009.htm
    "thatcadguy" skrev i meddelandet news:5902238@discussion.autodesk.com...
    Re: Mtext error
    04-11-2008 01:46 PM in reply to: thatcadguy
    Alright, thanks, I'll do that in the meantime.
    Valued Mentor
    Re: Mtext error
    04-14-2008 10:19 AM in reply to: thatcadguy
    Or if you already have an older installation of AutoCAD on your computer just copy the .dct files over from there.
    ____________________________________________________________________________________________
    System specifications: AutoCAD 2014 64-bit, Windows 7 64-bit SP1, Intel Core i7-2600K, AMD FirePro V4900
    16GB RAM, Crucial M4 SSD, 3 Dell Monitors (2 30" 2560x1600 & 1 20" 1200x1600)
    Re: Mtext error
    04-14-2008 10:44 AM in reply to: thatcadguy
    I did it the long way and found the DVD and copied from it. Thanks fellas. It took that error away.
