AutoCAD 2007/2008/2009 DWG Format
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Move / Scale Commands
- Highlight
- Email to a Friend
On one computer, I used to type "m" for move and "sc" for scale and it would work. I've recently been using another PC and it will not accept these commands. I have to type "move" and "scale". Anyone know how I can get it back to just using "m" and "sc". There's probably other commands that are behaving in this fashion but these are the only two I have tried. Thanks.
Re: Move / Scale Commands
- Highlight
- Email to a Friend
You can copy the ACAD.PGP from the one that works to overwrite the other one
or Go to Express menu and use Command Aliases editor.
- Highlight
- Email to a Friend
I took one from another PC that works but I still have the issue. I'm assuming you're talking about the acad.pgp in c:\program files\autodesk\mdt 2008\acadm\ ?
- Highlight
- Email to a Friend
(findfile "acad.pgp")
Copy the whole line above, go to the PC that works, paste in the command line, hit enter key
Whatever path it shows up, is where the ACAD.PGP you should copy to the PC that you want it to work.
Another reason it may not work is because an autolisp has taken over the acad.pgp commands during start-up.
- Highlight
- Email to a Friend
That command returns "nil" in the command history window.
- Highlight
- Email to a Friend
in which PC? the one that "m" and "sc" doesn't work ?
- Highlight
- Email to a Friend
Yes, the one that doesn't work. But you were right, the one that does work is pointing to a network share. I took the file in that share and put it in my directory, but it's still not working. Most likely because my Autocad is also trying to look in that share which has not been mapped in Windows yet (I have no network shares mapped yet). Which of the paths in the options is the one I want so I can repoint it to my own directory on my hard drive?
- Highlight
- Email to a Friend
Likely you don't have to map to any folder because SUPPORT folder is the main one and I don't think anybody would remove its path.
Copy the ACAD.PGP to your SUPPORT Folder.
