• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    Active Member
    jennielowery
    Accepted Solution
    Modify Tools not functioning properly
    173 Views, 7 Replies
    02-14-2012 08:43 AM
    Ok, this may or may not be an odd question, but here goes.
    I am currently using AutoCAD Mechanical 2007, up to date on all hot fixes and updates.
    I've been working all morning (and in the past) just fine, I click my objects, I type in my command (like CO for example) and I modify my object.
    I get up and walk away from my desk, come back and sit down, go to copy and object .. doesn't work right.
    It still works, but now it's as if I didn't select the object first.  Now if I select an object, type in the command CO (or any other modify command) or click the toolbar button, it turns my crosshair into the suare and asks me to select an object, thenI have to hit enter to select it.
    Now I know tons of peopel don't select their objects first, but imo it's a lot faster to select them type in your command .. it saves me an extra step (I modify 3d objects all day so saving 1 step for each time i have to modify something really adds up for me ).
    Here was my step process: (for exampls to copy an object multiple times)
    Select Object(s)
    Type in command CO, enter
    Click object and start copying
    Here is my step process now: (same example, copying)
    Select Object(s)
    Type in CO, enter
    Select Object again
    Hit enter
    Select object and start copying
    Even if I type in Co first .. I still have to hit enter .. which is an extra step and while it may seem like it shouldn't add that much .. I'm not used to having to do it and I have to mentally stop and think about it which means my productivity is slowing down ARGH!
    I've checked my DEMANDLOAD and it's at 3 where it should be.  I've rebooted both ACAD and my PC.  And this is a fresh install (I had another problem last week so IT came and just re-installed it on my pc).  It was literally fine 1 minute and not the next. SHM
    Help, Please ..?
    Please use plain text.
    *Expert Elite*
    Patchy
    Re: Modify Tools not functioning properly
    02-14-2012 08:59 AM in reply to: jennielowery
    Maybe it's the PICKFIRST should be 1
    Active Member
    jennielowery
    02-14-2012 09:05 AM in reply to: Patchy
    OMG .. I so LOVE you right now!  :heart:   :smileyvery-happy:
    I have NO idea how that got changed (as I've never typed in that command in my life, or needed to) but it worked!
    :happy dance:
    *Expert Elite*
    Patchy
    02-14-2012 09:06 AM in reply to: jennielowery
    I would dust the keyboard, lift the fingerprints and kick somebody's behind
    Active Member
    jennielowery
    02-17-2012 10:43 AM in reply to: Patchy
    lol, funny thing is .. there are only 2 AutoCAd operators here .. and the other lady wouldn't have had a clue how to do that haha .. I have to draw most of her 3D pieces for her to insert.
    My AutoCAD has been acting stupid lately though.  I'll be glad when the IT guy gets my new PC ready (I'm looking at it in the next cubicle lol) and I can start using 2012 .. maybe then I won't have so many weird issues (like now I can't subtract without fatal excepting .. i give up haha) lol.
    Thanks again!
    Valued Contributor
    02-20-2012 12:56 AM in reply to: jennielowery
    Certain commands like MVSETUP and others can change several variables by themselves.
    Active Member
    jennielowery
    06-27-2012 06:49 AM in reply to: jruifer
    I just had the same problem happen again and I do believe it was the MVSETUP, as mentioned above (as that is the command I was using right before it happened).
    Any idea of why this changes the PICKFIRST?
    That's very curious! :smileyindifferent:
    Active Member
    jennielowery
    06-27-2012 07:35 AM in reply to: jennielowery
    Really?  Hmm .. well I am using 2012 AutoCAD .. any idea why mine is doing this then?
    I figured out why my co-worker's never does this .. she never uses MVSETUP to rotate the view in her viewports (she just rotates it in Model, which isnt' optimal as it rotates the text/dimensions as well).
