• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    *Pro
    scot-65
    Linetype Scaling in Viewports - Independently?
    415 Views, 3 Replies
    06-19-2012 03:54 PM
    I'm not much into viewports, but the guru who is, is having difficulty with this one...
    He has a overall "Master" drawing.
    He creates 2 viewports that reference this overall drawing on the same page:
     - An overall "thumb view" of the drawing at 1"=30'-0".
     - A zoomed-in view at 1/8"=1'-0" scale.
    For the linetypes (dashdotx2) to look proportionate, the overall 1:30 scale viewport should
    have a LTSCALE of 45, while the 1/8 scale viewport should have a LTSCALE of 18.
    How to do this?
    Scot-65
    Please use plain text.
    *Pro
    nestly
    Re: Linetype Scaling in Viewports - Independently?
    06-19-2012 05:09 PM in reply to: scot-65
    If LTSCALE, MSLTSCALE, PSLTSCALE and CELTSCALE are all 1, then AutoCAD will scale the linetypes correctly regardless of the viewport scale.
    PaulMunford
    06-20-2012 12:07 AM in reply to: scot-65
    This tutorial may help to explain how the different values stack up:
    http://cadsetterout.com/autocad-tutorials/line-type-scales/
    Let us know how you get on!
    Paul
    The CAD Setter Out Blog
    @CadSetterOut
    Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
    *Pro
    scot-65
    06-22-2012 03:20 PM in reply to: PaulMunford
    We will try PSLTSCALE...
    Thanks.
    Scot-65
