• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2007/2008/2009 DWG Format
    Active Contributor
    Insert DWF underlay
    437 Views, 5 Replies
    04-19-2011 03:24 AM
    Please help.
    Cannot insert DWF underlay into DWG file.
    I just get a blank rectangle formed by a line.
    I use Autocad Design Review 2012 to turn a pdf into a dwf file, then try and insert DWF underlay
    Please use plain text.
    New Member
    dcbenson001
    Re: Insert DWF underlay
    04-19-2011 07:15 AM in reply to: jakeslicks
    If you are using 2010 or above, you should be able to attach the PDF directly.
    Active Contributor
    04-19-2011 09:34 AM in reply to: jakeslicks
    i have aotucad lt 2008....you think thats the reason its not working?
    thanks
    New Member
    dcbenson001
    04-19-2011 09:41 AM in reply to: jakeslicks
    I would check the forum for compatability between DR2012 and ACAD 2008. That sound like the most logical reason it is not functioning properly.
    Distinguished Contributor
    04-19-2011 09:48 AM in reply to: jakeslicks
    i have been able to convert PDFs to DWF and have it attach in 2009 w/ no problems. but the DWF file is way bigger than the PDF. A converted DWF from PDF will behave the same as an image attachment. You might be better saving your PDF as an image and attaching the image instead.
    Active Contributor
    04-19-2011 03:53 PM in reply to: jakeslicks
    WHen you say save the pdf as an inmage...do you mean when I open it in ADR ??How do i do dat?
    Its wierd too...when I try to insert the dwf in a dwg file...its about 4 million feet long.
