AutoCAD 2007/2008/2009 DWG Format
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
How to open PDF as landscape?
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
5503 Views, 11 Replies
04-10-2008 06:28 AM
Hello
I hae many pdf sheet, and each time I open one of them, it is portrait, and I had to rotate the sheet as landscape,
How can I set it up to open every time as a landscape?
thanks
thanks
Re: How to open PDF as landscape?
Options
- Highlight
- Email to a Friend
04-10-2008 08:12 AM in reply to:
camohano
It's not "opening" in portrait, that's how the document was created. If you
created it out of AutoCAD then you have to tweak the print settings of your
pdf driver so it will produce a document in landscape.
wrote in message news:5900517@discussion.autodesk.com...
Hello
thanks
Hello
thanks
*Jimmy Bergmark
Options
- Highlight
- Email to a Friend
04-10-2008 08:37 AM in reply to:
camohano
The best way is to create them with correct rotation directly.
Other than that it is depending on what program you use to view the PDFs if
it is possible or not.
Jimmy Bergmark
JTB World - CAD software, development and consulting
Owner/Developer
http://www.jtbworld.com
http://blog.jtbworld.com
JTB FlexReport (FLEXnet / FLEXlm license report tool) -
www.jtbworld.com/jtbflexreport
AutoCAD 2009
http://www.jtbworld.com/autocad2009.htm
"camohano" skrev i meddelandet news:5900517@discussion.autodesk.com...
> Hello
> thanks
Jimmy Bergmark
Owner/Developer
AutoCAD 2009
> Hello
> thanks
Options
- Highlight
- Email to a Friend
04-10-2008 10:22 AM in reply to:
camohano
I always make my PDF's set as landscape and they too always open as portrait, not just from AutoCAD either. This is an issue with Adobe Acrobat, that thinks pages are always portrait.
Additionally if creating custom pages in Acrobat Writer you need to ensure that they are defined by the portrait size otherwise they will crop incorrectly.
*Jimmy Bergmark
Options
- Highlight
- Email to a Friend
04-10-2008 11:05 AM in reply to:
camohano
It can be a little tricky to get it work depending on version you have of
Acrobat but it sure is possible to have them created "correct".
Jimmy Bergmark
Owner/Developer
AutoCAD Automation Tools
http://www.jtbworld.com/autocad_automation_tools.h tm
AutoCAD 2009
"Laxtor" skrev i meddelandet news:5900905@discussion.autodesk.com...
> incorrectly.
Jimmy Bergmark
Owner/Developer
AutoCAD 2009
> incorrectly.
Options
- Highlight
- Email to a Friend
04-10-2008 11:06 AM in reply to:
camohano
You have to change the orientation of the plot from the pdf driver
properties, not just the AutoCAD layout. Set the orientation to rotated
landscape. Ignore the sheet layout preview in the AutoCAD plot properties it
shows it as portrait but will come out landscape. see attatched image.
wrote in message news:5900905@discussion.autodesk.com...
incorrectly.
incorrectly.
*Dean Saadallah
Options
- Highlight
- Email to a Friend
04-10-2008 01:06 PM in reply to:
camohano
Or try this freebie if you still cannot get it to work:
http://www.noliturbare.com/PDFtools.php
Dean Saadallah
http://LTisACAD.blogspot.com
Add-on products for LT
http://www.pendean.com/lt
Dean Saadallah
*Alain Cote
Options
- Highlight
- Email to a Friend
04-10-2008 01:57 PM in reply to:
camohano
If the files were created with Acrobat Pro 06 drivers then portrait it is.
I have not been able to get that driver to create landscape in any way. If
the files are not rotated at creation then you have to rotate. I do not
know but you may be able to create a batch routine in Acrobat to rotate all
the files. When we create the PDFs they need to be rotated and that gives
my users the opportunity to "eyeball" the files to make sure all is ok
before they are distributed, that is if they even bother.
ACote
Hello
thanks
ACote
Hello
thanks
Options
- Highlight
- Email to a Friend
04-11-2008 07:19 AM in reply to:
camohano
hello BBerger
thanks man, I tried and it worked just fine, thanks again
Options
- Highlight
- Email to a Friend
08-13-2008 02:06 PM in reply to:
camohano
IF you have Acrobat Pro, CTRL+R or CTRL+SHIFT+R. This actually rotates the image.
If you have only Acrobat Reader, View, Rotate View. This doesn't "stick"
I make a LOT of PDFs some days. I have found it helpful to create "custom" paper sizes for the PDF driver for landscape Arch E and E1.
Peace,
- Sequoia
Peace,
- Sequoia
