AutoCAD 2007/2008/2009 DWG Format
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
How to draw shapes using equations?
- Highlight
- Email to a Friend
- Report Inappropriate Content
I want to draw an exponential taper 2D structure having a particulare taper equation.
How can I draw such shapes?
Thank you for your help.
Nirmal.
Re: How to draw shapes using equations?
- Highlight
- Email to a Friend
Calculate a few points and then place a spline between the points.
Calculate twice as many points and create a new spline.
Is there a significant (manufacturable, measurable (using standard measuring tools - not AutoCAD) difference between the two curves?
If not then you might try again with half as many points as the first curve.
You could find out that you need to calculate far fewer points than you might think.
- Highlight
- Email to a Friend
Thank you for your reply.
I am designing the optical waveguide & it design changes might affect my final feild response after passing through all the components.
I have all the co-ordinates/points(around 7000) for the curve:
Can I plot all the points using some function line pline or spline?
If yes, can you elaborate the way to enter the co-ordinates?
Somebody suggested me to copy paste x & y co-ordinates. but I am not able to do that.
Thank you.
Nirmal.
- Highlight
- Email to a Friend
Get 30 free trial C3D and bring in the points if they are that many.
- Highlight
- Email to a Friend
nirmalp wrote:Hello,
Nirmal.
I think something like Autodesk Inventor would be a better tool for this application.
I'm sure there is probably a list out there that willl draw a spline from a list of points, but -
where did these points come from? Caculated? Scanned point cloud?
If calculated I'll wager that just as good results could be obtained from 70 points and maybe far far fewer.
In Inventor you can enter points from Excel
or
enter Equations directly.
The advantage to the second method is if you need to tweek the numbers - the model will automatically update.
If you must use AutoCAD this might help http://www.google.com/#hl=en&tbo=d&output=search&s
