• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    Active Member
    How to delete one(or more) of a rectangle's lines
    308 Views, 3 Replies
    12-08-2012 03:04 AM
    How can I delete one of the rectangle's lines? When I try selecting only one line I can't do it unless I select the entire rectangle. Help please.
    For example in this photo I would like to delete line AB:
    [IMG]http://i49.tinypic.com/11a9uzm.jpg[/IMG]
    Please use plain text.
    Re: How to delete one(or more) of a rectangle's lines
    12-08-2012 03:18 AM in reply to: Cantafford
    if your rectangle is of type POLYLINE then it's one object. To separate the polyline into it's segments you may use command _EXPLODE, then each of the segments will a be separate line and may be deleted piece by piece.
    (just to make sure: to move that object, when it's exploded, makes it necessary to select each of the pieces :smileywink: then )
    - alfred -
    Alfred NESWADBA
    Active Member
    12-08-2012 08:57 AM in reply to: alfred.neswadba
    Great thanks man!
    Valued Mentor
    12-11-2012 06:50 AM in reply to: Cantafford
    Since the Rectangle is a polyline, it is an Object. As an Object, it can trim itself. Here's how.
    -Start the Trim command,
    -Select the Rectangle,
    -Hit "Enter" to end the selecting.
    -Now, select any of the Rectangle's lines and they will disappear.
    The remaining pieces are still Polylines.
    Try it; you'll like it. -KLYPH
